MF1155 problems
Wes Miller
01-23-2005 16:03:43
i have a mf 1155 with 5700hr on it and a lot of blow by woundering any way to stop other then rebuild also hase an leak that makes it hard to start after sitting over night it will fire right off them stall and requires a lot of cranking and either sometimes you have to bleed the fuel lines any ideas on how to fix and is there any way to make the cab quitier
JoeMN
01-25-2005 14:38:20
 Re: MF1155 problems in reply to Wes Miller, 01-23-2005 16:03:43
Chek for leaks between the filters and injector pump. If those little rubber compression seals on your fuel lines are cracked,hardened,shrunken you will lose your prime after you shut it off.Also make sure you have clean fuel filters. Regarding cab noise,you may need new rubber donuts where the cab mounts. The stock muffler quieted the engine very well for the operatorbut produced a whistling noise that culd be heard for quite a distance. Some people remedied that by poking a crowbar down the pipe. If your original muffler has been altered or replaced excessive noise in the cab will be the result.If you have done everything to quiet the cab(rubber mounts,weatherstripping,floor mat,cab acoustic liner,fit door and windows)and it is still too loud,get some Bose noise reduction headphones.They work.
