SUPER 90 fuel pump
uedlose
01-22-2005 13:08:52
any one know where I can get a rebuild kit.I think I may need one and the filters for it.I keep getting air in the system some how.it runs fine then just shuts down I check the bleed at the injection pump and there is air.any one have a clue it is a perkins diesel I guess there could be a seal leaking and it is sucking air there. the pump is a A/C pump so I would think some one has a rebuild kit for the pump.
Bob N.Y.
01-23-2005 16:16:55
 Re: SUPER 90 fuel pump in reply to uedlose, 01-22-2005 13:08:52
I had a similar problem with a 165 diesel. It turned out to be a cracked diaphragm in the fuel transfer pump. I couldn"t see the crack until I held it up to the sun.
Fred Wolfe
01-23-2005 10:14:34
Do you have the parts book for your super 90 ? I have a super 90 diesel. Email me the part numbers?
JIMLLL
01-22-2005 14:26:33
Sorry, I do not know of a source of fuel puump, but I had a similar problem with my Super 90 and found a crack in a fuel line. Removed it, silver soldered crack, reinstalled and it works great.
uedlose
01-23-2005 04:31:21
 Re: SUPER 90 fuel pump in reply to JIMLLL, 01-22-2005 14:26:33
Yea I need to do that and take a good look at lines and seals but I sure would like to get some filters for it also.Thanks John
JIMLLL
01-26-2005 08:36:04
 Re: SUPER 90 fuel pump in reply to uedlose, 01-23-2005 04:31:21
SUPER 90 FILTERS; I obtained from NAPA
ENGINE OIL = NAPA No. 1099
FUEL = NAPA No. 3166, (2 REQD)
uedlose
01-27-2005 04:00:21
 Re: SUPER 90 fuel pump in reply to JIMLLL, 01-26-2005 08:36:04
thanks that helps
