MASSEY HARRIS 25
STUDEdiesel63
01-22-2005 09:16:42
Am restoring a massey "25",whats a good torque for the head bolts and rod caps??Original shop manual gives no specs,I don`t want to guess.
wolfe in tx
01-24-2005 17:23:33
 Re: MASSEY HARRIS 25 in reply to STUDEdiesel63, 01-22-2005 09:16:42
The massy harris 25 has the same engine as the pacemaker and challangers> I looked in my manuals and can"t find any numbers. Maybe someone can help us i need them too. Wolfe
ray-sn
01-24-2005 17:01:45
Continental manuals give torque by bolt/stud size and application rather than by engines. For 3/8": head 35-40 (later manual says 45-48), mains 35-40, rods 40-45 (later manual says 45-50). For 7/16": head and mains 70-75, rods 55-60. For 1/2": head 100-110, mains 85-95, rods 90-100. Hope this helps. ===== ===== ===== ===== ===== ===== ===== ===== ===== ===== =
Tech Tip #8 - The 4107/8 Rides Again
Perkins 4107 (known also as the Westerbeke 40) engines have been out of production now for roughly two decades. New 4107 cylinder heads and short blocks are no longer available from the factory. Perkins doesn't even offer 4107 engine overhaul parts kits. But Foley Engines - the oldest engine dealer distributor in North America - can help 4107 owners! We can get you back up and running quickly and inexpensively. For those of you who want to rebuild your present engine we have Foley Engine parts Kits. These kits contain the correct 4107 internal parts including wet sleeves and "O" rings. (Unforunately, the less expensive 4108 internal parts can't be used to rebuild a 4107.)
Link
there are some torque specs here..
AllanC
01-23-2005 19:49:36
What size are they?
