Rod Bearings NEEDED ASAP
Mark Lemanski
01-18-2005 08:52:53
I have a massey harris 44 that i am rebuilding and i need a set of rod bearings that have the .002 undersize. I had the crank ground and i cannot find these bearings anywhere in the area in central wisconsin. If you are somewhat close, within 300 miles or so and can get them to me by thursday, you would be a god. This tractor is my shop project and i need to complete it HELP ME ALL
jjl
01-18-2005 15:02:44
 Re: Rod Bearings NEEDED ASAP in reply to Mark Lemanski, 01-18-2005 08:52:53
Not sure if I have any .002, but I do have .010, .020, & .030. Let me know if you need any.
Thanks,
Jeff
Tom Dold
01-18-2005 13:13:58
Mark
I have a set of .002 undersize bearings for a 260 Continental. You stated the crankshaft was ground. Are you sure you that it wasn't ground .020 undersize? If a standard crank is worn a little, one can get by with .002 undersize bearings. I have never heard of anyone who would actually grind a crankshaft .002 under. As far as .020 underesize rod bearings I only have three.
Tom Dold
Dold Implement Co.
Howard, SD 57349
605-772-4541
[email protected]
