Fuel gauge on MF135
MF135newbe
01-18-2005 05:37:36
I recently acquired a MF 135 which the fuel gauge does not register. I used an ohm meter and get a reading between the terminals of the fuel gauge but when I take a reading between the contact point on the tank sending unit and ground I get no reading. The tank is 3/4 full and using new wires and and checking with a voltmeter, I am getting 12 V to the circuit. Does the lack of an ohm reading suggest that it is the sending unit is defective? If someone familiar with these units could give me a suggestion I would greatly appreciate it.
Gerald J.
01-18-2005 07:43:50
 Re: Fuel gauge on MF135 in reply to MF135newbe, 01-18-2005 05:37:36
The wiper in the sender could be worn down so it doesn't touch. You can inspect that and maybe end it back in contact after you pull the sender from the tank. Check from sender terminal to sender plate before you go that far. Getting a ground through the gaskets sometimes fails.
The float on mine took on gas and sank. Now its a cork coated with SealAll.
Gerald J.
Lou
01-20-2005 08:07:42
 Re: Fuel gauge on MF135 in reply to Gerald J., 01-18-2005 07:43:50
We have a MF135 with the 3 cylinder perkins diesil you dont need a fuel gauge because it uses so little fuel! Lou
