FE 35 black oil
kim ward
01-16-2005 20:38:21
I have an Fe 35 with a perkins deisel runs good but after I change the oil and put it to work for a day or two check the oil, level is good but the oil is black , can't see through it on the dip stick.Is this normal for this engine? I also own a Fendt 305 lsa deisel oil is stiil clear after 500hrs.On a different note ,does anyone know where I can get a primary fuel line from the tank to the lift pump,I don't think mine has the right fitting on the lift pump end , won't stop leaking even with new pump, dealer says can't supply.
Peter Booth(AUS)
01-20-2005 00:37:04
 Re: FE 35 black oil in reply to kim ward, 01-16-2005 20:38:21
Hi kim
Not unusual for a diesel to blacken up the oil almost straight away after an oil change. A lot depends on its history of service and how much sludge build up there is in there. You could try giving it a change every 20 hours for 3-4 changes and this would improve it i think.
