MF135 (UK) timing case
wombat
01-14-2005 01:58:43
I require a replacement timing case for a burnt UK built MF135. The part no is 37161270 AA3. A number of different timing cases are available. Will any others be suitable? Tried a timing case off a US industrial motor but the harmonic balancer from the tractor motor will not fit without machining.
DavidP, South Wales
01-14-2005 12:21:59
 Re: MF135 (UK) timing case in reply to wombat, 01-14-2005 01:58:43
Hi, You certainly have the right number.
37161271 is correct up to engine (UK) UA228489D
37161481 is correct from UA 228489D
You mention one from a US motor. Are you sure it was from a Perkins 3.152 engine? The spread of 3 pistons around the crankshaft revolution does not create vibrations that require a balancer of the Lanchester type fitted to 4 cyl engines. With a 4 cyl vibrations are created when two pistons reach TDC and two reach BDC at the same time....going from high speed to standstill however brief, in an instant.
Cheers
David P
