MF 135 Gas, Tach/speed cable plate weep hole
JWyatt NC
01-12-2005 17:25:09
On my 3 cyl perkins gas, what is the purpose of the weep hole in the tach/speed cable plate thats bolted on backside of engine?Can it be sealed? And what is the best way to stop oil leak around nut that holds cable in? Ya'lls help is always appreciated. This site has saved my tail.
Arthur from Tassy
01-13-2005 04:10:56
 Re: MF 135 Gas, Tach/speed cable plate weep hole in reply to JWyatt NC, 01-12-2005 17:25:09
Hi there
If you where to block that hole the oil would quickly fill the cable and possibly the tacho, take the plate off and inside it you will find a seal that needs replacing. also get and fit a new gasket under the plate and it should be good as new.
Cheers Arthur from Tassy
JWyatt NC
01-13-2005 12:45:34
 Re: MF 135 Gas, Tach/speed cable plate weep hole in reply to Arthur from Tassy, 01-13-2005 04:10:56
Thanks, will give it try.
