EXTERNAL HYDRALICS FOR TO 30
CHRIS GENTILE
01-12-2005 16:44:53
i HAVE A TO 30 QND WOULD LIKE TO USE A HYDRALIC FENCE POST DRIVER THAT REQUIRES 1800 PSI AND 6GPM FLUID. hAS ANYONE MOUNTED A EXTERNAL HYDRALIC PUMP ON A TO 30?
marlowe
01-12-2005 18:23:23
 Re: EXTERNAL HYDRALICS FOR TO 30 in reply to CHRIS GENTILE, 01-12-2005 16:44:53
you can run them off the front of the crank shaft but it's a lot of work to made brackets best is to run a pump off the PTO i have one set up that way and use a remote valve [two way] use the oil from the tractor rear end just drilled and taped some ports
