starter motor spacer blocks
Yellott Canby
01-11-2005 20:30:56
Hello, I was wondering if anyone knew where I could find a starter spacing block. I am putting a starter off a 354 Perkins diesel engine into an application where a 4.236 engine was. The nose on the starter is too long and I need to move it back around 7/8" to match up with the ring gear. Any thoughts.
Thanks YC
Make mine a Massey
01-12-2005 04:32:26
 Re: starter motor spacer blocks in reply to Yellott Canby, 01-11-2005 20:30:56
Had the same problem switching from a Delco to a Lucas on a 318 Perkins , only I ended up with a block that I didn't need. 3 holes about 3/4 inch thick. Try your dealer , . if not let me know. It's not very big , so shipping would not be a problem.
Yellott Canby
01-12-2005 18:53:08
 Re: starter motor spacer blocks in reply to Make mine a Massey, 01-12-2005 04:32:26
Hello, thanks for the reply. I will try the dealer and if not I may holler back about your block. 3/4" may be enough. Is yours aluminum?
Thanks YC
Make mine a Massey
01-13-2005 03:13:12
 Re: starter motor spacer blocks in reply to Yellott Canby, 01-12-2005 18:53:08
Yes
