MF 35 Diesel Transmission Stuck
Chip Fontaine
05-30-1998 12:32:21
I purchased this machine about 2 months ago and have used it extensively with a grader blade and bush hog.
Today while cutting grass, the need to backup arose and I shifted to reverse and then could not get the tractor out of reverse.
Is this a typical problem with this type transmission? Any ideas on how to remedy this?
Thanks,
Chip
Jack in NB
05-31-1998 05:25:45
 Re: MF 35 Diesel Transmission Stuck in reply to Chip Fontaine, 05-30-1998 12:32:21
Hi Chip -
Common problem. Shift lever wears at the bottom end, and jumps up (or gets pulled up by the operator) against the downward spring pressure in a fast shift.
Shift the hi-lo lever to neutral, clean off the transmission oil filler cover, remove it, and go in with a long clean heavy screwdriver and move the sliding gear forward.
Reseat the gear shift lever - you may be able to get it by lifting, or you may have to remove the retaining pin (about 1/4 x 1 1/4) under the rubber boot.
We have built some up with brazing to correct the problem.
Chip Fontaine
05-31-1998 16:03:30
 Re: Re: MF 35 Diesel Transmission Stuck in reply to Jack in NB, 05-31-1998 05:25:45
: Common problem. Shift lever wears at the bottom end, and jumps up (or gets pulled up by the operator) against the downward spring pressure in a fast shift.
: Shift the hi-lo lever to neutral, clean off the transmission oil filler cover, remove it, and go in with a long clean heavy screwdriver and move the sliding gear forward.
: Reseat the gear shift lever - you may be able to get it by lifting, or you may have to remove the retaining pin (about 1/4 x 1 1/4) under the rubber boot.
: We have built some up with brazing to correct the problem.
Thanks for the info. I did as you said before I read your message. I was blindly moving and rattling things in the transmission case when the shift lever just poped back to a neutral position.
I then tried the other positions in the shift pattern and all seemed well. After about 2 hours of bush hoggin and post hole digging, it still acts normal. I hope this does not happen frequently from here on out.
Thanks again .
Chip
