Welcome aboard, Peter. The MF35 is a great little tractor, and its owner's loyalty comes as a result of the machine's usefulness, rather than in spite of its foibles. A couple of questions will come up time and again, so you might as well prepare the answers to them ahead of time. Is it a four cylinder or at three cylinder diesel? Standard built the fours up until about 1960, and Perkins took over after that. Your dealer will want to know if it is an American or a British model. The plaque on the dash should take care of that. Is it a 35 or a 35 DeLuxe? The DeLuxe models have a second PTO setting which confuses the daylights out of newbies. If you find you have it, don't use it until you get some advice. The PTO lever pulls up for normal PTO and down for the ground-speed setting. The trouble is that it will turn an implement backwards if you reverse, and this isn't always good. The most pressing maintenance need, from my experience since November, is likely the air cleaner. Mine hadn't been cleaned for a very long time. Lay in a gallon of cleaning fluid, some rags, and disposable clothes. Changing the transmission fluid was a real adventure, largely because I had a hard time figuring out how much fluid was in the transmission -- a lot, but not the ten imperial gallons I poured in. I think it held onto about eight of that. Anyway, when you take a plug out of the transmission, you'd better have a big pan there to catch what comes out. Engline oil changes are interesting if you haven't dealt with a cannister oil filter before. No problem. Just take the thing apart, put the replacement in so that the oil filter can work, and go for it. Use the recommended oil. The guy who sold my 35 to me warned me sternly not to start the tractor if I wasn't sitting on the seat. The safety interlock on my machine is not connected, so it would be very easy to reach over and start the machine in gear, and then get driven over by one of the back wheels when it surges forward. Get an owner's manual. It is very helpful. Unless you are an engine service tech, though, forget the Massey Ferguson Workshop Service Manual. I have found it useless, as all it does is explain how to rebuild engines and transmissions. A parts manual would be nice, but they are very expensive, even on eBay. Today's task was the fitting of tire chains. Lesson learned? Chains which fit 28 X 11.4 tires need about 8" of extensions to fit a 28 X 12.4 set. You'll have to let us know what it's like outside where you live. If it's cold, we northerners will have a lot of survival advice. (If the road is so icy one of your front wheels stops turning while you're driving, watch out. A spin-out is gonna happen right away.) The Texans will no doubt have instructions on driving in the south -- t-boning armadillos, avoiding cactus spears in the tires and rattlesnake bites, I suppose. We'll leave that up to Mark. Glad to have you on the list. You'll find the contributors are generous, clever, and quite often well informed.
