MF65 loader hookup
homer long
01-07-2005 08:16:33
Can anyone tell me on a 65 which port is pressure my tractor as transfer plate on top which I have the 2 rear ports hook to single spool valve to the rear to operate haybine cylinder and now putting loader on and there is one port coming out the front of transfer plate and another on side down a little lower on main houseing. The transfer plate has 3 positions handle straight up lets 3pt.operate/handle to rear when using rear remotes / handle to front for loader but which is pressure port
Big Dean
01-08-2005 08:59:16
 Re: MF65 loader hookup in reply to homer long, 01-07-2005 08:16:33
If you have the diverter valve on top of the liftcover right in front of the seat that I thing you have from the description you posted. The lower port on the rear of that valve is a return to the reservoir. The top port on the back is a pressure port when the handle is turn to the back. The front port is a pressure port when the handle is turned to the front. You can run a line from the front port to the IN on the loader valve & put a tee in the return on the back of the valve and run a line from the OUT on the loader valve to the tee. If I can be of further help with this Email me Big Dean
