mf135 ps leak
JONJ
01-06-2005 07:51:41
i just discovered my '67 135 diesel has power steering. duh! when i tried to fill it leaks faster than i can fill it! leaking from the breather on top of the case. i looked in past threads and found some info but its not clear. now i have several questions. what can cause this? what type of fluid should i be using? btw this is a usa mf135 perkins diesel with cessna(pancake) ps pump. the steering box is on the tranny case. i love my little machine but it definatly is a fixer-upper. thanks big time guys!! jon
Big Dean
01-06-2005 11:39:58
 Re: mf135 ps leak in reply to JONJ, 01-06-2005 07:51:41
If I am understanding what you are describing you have oil coming out the breath on top of the steering gear just behind the cylinder. If that is right the seal for the cylinder piston polish rod is bad causing this problem. If I can be of further Email me
JONJ
01-07-2005 05:54:42
 Re: mf135 ps leak in reply to Big Dean, 01-06-2005 11:39:58
thanks Dean. i'll have a better look at it this weekend. btw i stand corrected it is a 1974 mf135 according to the ser# page. thanks again. Jon
