MF 20 Industrial Gas
Tom G
01-05-2005 03:27:30
I need a wiring diagram for my MF20 Ind. Gas If you have, please email diagram to [email protected]
Thanks, Tom
Tom G
01-06-2005 10:48:52
 Re: MF 20 Industrial Gas in reply to Tom G, 01-05-2005 03:27:30
Thank"s for the quick and helpful response with the wiring diagrams. Very much appreciated.
Another problem I"m working on, is the throttle. I may have broken and/or lost a spring (Don"t know if there was one)from the throttle to governor lever. When starting the tractor there is no control of engine rpm unless I manually control it at the carb. Hand and foot linkages are conected. I hooked a small bungee from governor lever at the engine to the throttle control at the carb works for now but this doesn"t allow the goveror to work properly.
My manual does not show or explain this clearly.
If anyone has a good diagram and/or explanation please send to [email protected]
Thanks, Tom
