Massey-Harris GP
Marc Buseyne
01-04-2005 10:00:04
Can someone tell me what the oil content (volume) is of the gear box? And how can I check the oil level? Please help me!!
Jim - Illnois
01-07-2005 06:45:30
 Re: Massey-Harris GP in reply to Marc Buseyne, 01-04-2005 10:00:04
On the right side, just above the foot rest, is a 3x5 or so plate held on with two bolts. That is where the transmission oil is checked and filled. The book says it taked 4 gallons and 1 Qt. oil, but it seems it took more than that. The low point drain plug is in the area of the belt pulley on the left side of the bottom plate.(Sounds confusing, but you'll see when you get under there.) Refill to the botton of the sliding gear shaft retainer. (The oil needs to just touch the bearing on the shaft going to the rear of the case. The oil will just cover the bottom of the compartment the shifting controls are in.) The book calls for the same oil the motor takes, but I used 80-90W, since it is only run a few times a year. Hope this helps.
