Rear Tires/Wheel Size For 165
Tim PloughNman
01-03-2005 16:05:46
Greetings to my Friends -
I normally post on the N-Series board but a fellow at work has a Massey-Ferguson 165 and needs new rear wheels. Originals are victims of CaCl. What size wheels should I get for him? I have not seen his tractor. Thansk.
Tim Daley
Arthur from Tassy
01-04-2005 02:54:35
 Re: Rear Tires/Wheel Size For 165 in reply to Tim PloughNman Daley, 01-03-2005 16:05:46
Hi there Tim
I take it that CaCl is added to the water in the wheel for extra weight? I had a look at this site ----- --://hillbrothers.com/hi94.htm but was none the wiser.
As for your question the rim sizes vary greatly depending on what tyres are fitted to the tractor and what it is to be used for.
i.e. for draw bar work on steep hilly country a 23.1x26 tyre works well on shallow dry soils.
for mouldboard ploughing a 12.4x36 that fits nicely into the furrow is also a good allround farm tyre.
for rowcrop work a narrow but tall tyre 9.5x42 is a good choice.
According to a Australian sales pamphlet I have on the 165, the tractor could be ordered with 18.4/15x28 or 16.9/14x28 with pressed steel rims and 640lb cast centres, - 16.9/14x30 , 16.9/14x28 or 14.9/13x28 on pressed wheels.
All of these tyre sizes have a loaded rolling radius of about 26"-27"
For the high clearance models, they used 14.9/13x38 or 13.6/12x38 with pressed steel wheels.
these tyre sizes have a loaded rolling radius of about 28"-29"
So there you have it, May I suggest you ask your friend the size printed on the side of his tyre case.
Good luck and cheers Arthur from Tassy
Crem
01-03-2005 21:09:03
My parts book for the MF 165 lists nine different rim assemblies for this tractor. The different diameters are 24,26,28,30,38, and even a 16 orchard wheel. There are also different widths available for some of these diameters. You may have to look at the tire size and then measure the width of the rim.
2x4
01-03-2005 22:17:11
 Re: Rear Tires/Wheel Size For 165 in reply to Crem, 01-03-2005 21:09:03
my MF 165 has 32 inch rear tires. so does my MF 65.
