MF 135
Lingdell
01-03-2005 10:48:18
I have a 1974 Massey Ferguson 135 diesel with a stock exhaust behind the rear wheels. I would like to convert that to a stack exhaust. Does anyone know what parts I will need? Do I need to change the manifold and the pipes? Any help or ideas would be greatly appreciated.
Davip P,South Wales
01-03-2005 13:44:52
 Re: MF 135 in reply to Lingdell, 01-03-2005 10:48:18
Hi,
No problem in changing to a vertical exhaust. You may have problems undoing the nuts/studs where the downpipe attaches to the manifold. The parts you need are;
898 011 M1 Elbow 1
827 877 M1 Gasket 1
0826 439 Stud 3
375 706 X1 Washer 3
375 718 X1 Nut 3
2 1/8" Clamp 1
894 291 M2 Silencer
DavidP
Richard in ID
01-03-2005 19:19:22
 Re: MF 135 in reply to Davip P,South Wales, 01-03-2005 13:44:52
Hi David P. You mentioned a part #894 291 M2 silencer as a portion of the assembly for a vertical stack conversion. What type of silencing it is for and where is it placed in the assembly? I have a 135 with a vertical stack and am curious if I have one on mine or not. Thank you. Richard.
DavidP,South Wales
01-04-2005 12:31:43
 Re: MF 135 in reply to Richard in ID, 01-03-2005 19:19:22
Hello Richard,
Seems like a difference in what we call them on this side of the pond. For us the silencer is the exhaust itself. You refer to it as a stack.
Maybe only Mr.Bond uses a silence!!!!
Cheers
David P
D
Richard in ID
01-04-2005 19:15:54
 Re: MF 135 in reply to DavidP,South Wales, 01-04-2005 12:31:43
Thank you for the explanation. Here in the state of Idaho, we call that a muffler. Interesting how several words can, ultimately, have the same meaning. Thanks again and have a great year over there, across the pond. Richard
