HELP ! I need help on the clutch/presure plate 135
GDBAR
01-03-2005 05:31:06
I was putting the clutch back onto the fly wheel
and have run into all kinds of trouble 1.it was next to imposible to attact the clutch to the fly wheel it seems that the same bolt that
came off the clutch are not long enough.
2.when I finely got the clutch attached had it alinged with the shafts and bolted onto the tractor the engine would not turn over so off it came to find that the presure plate housing had cracked.
what did i do wrong and is there a special tool to reatach the clutch to the fly wheel ?
Big Dean
01-03-2005 12:19:27
 Re: HELP ! I need help on the clutch/presure plate in reply to GDBAR, 01-03-2005 05:31:06
When removing & replacing The dual or better known as a two stage clutch pressure plate it should be bolted together before it is unbolted from the flywheel. If not some of the piece can fall out of place and when you bolt it back on the flywheel it will usually break something. I have pictures that show how to do that. If you will send me an Email address I will email them to you. You also need a special disc lineup tool that lines up both disc I also have a picture that shows all the dimensions so you can have one of them built at a machine shop.
