Just a few points for you to check that may save you pounds! 1. Starting at the front, if buying a 4wd check the wear in the front axel bushes as they tend to wear badly and if not replaced will let the axel tip, putting weight on the front axel pinion shaft which in turn wears away the splines on the pinion shaft which means a new crown wheel and pinion. 2. Gearbox, if possible avoid the 32 speed box with A B gear ranges, these in the past have caused many a problem and when new were subject to many changes by MF who ended up deleting this option all together. Check all the gears one by one and listen for grating and noises from the transmission in general. It may be that the transmission has been repaired in the past 7000 hrs, if not be aware that it is a very costly part of the tractor to repair if it is needed. 3. Check the hand brake, make sure it works, the hand brake is mounted on the pinion shaft in the rear axel, and if the tractor has been driven with it on it wont be any good. 4. Make sure all the electronic operated systems 4wd, diff-lock, PTO, speed shift and the ELC operate correctly. The wiring dose suffer from connectors corroding and causing problems On the whole a very nice tractor to drive and one of the first tractor ranges with electronics on the market. One with a good service history would be an advantage and you may be hard fetched to find one with out wireworm in the doors and roof. Hope this is of some help.
