Perkins Diesel leaking oil
Jon Turner
12-31-2004 03:54:30
I changed the head gasket, and tractor has been running fine for a month with no leaks. Today it starting leaking heavily. On the right rear of the block, there is a triangular flange bolted on, and on this flange is where the tachometer cable is connected. Below that connection on the flange there is a small hole (a weep hole???) and oil is pulsing out of that hole while the engine is running. What could be causing this????? I did not disturb or remove this flange during head gasket teardown.
TomTX
12-31-2004 05:49:09
 Re: Perkins Diesel leaking oil in reply to Jon Turner, 12-31-2004 03:54:30
What model tractor?
What engine?
What was wrong that you replaced head gasket?
DavidP, South Wales
01-01-2005 12:14:00
 Re: Perkins Diesel leaking oil in reply to TomTX, 12-31-2004 05:49:09
Hi,
Could be a bit of bad luck. Make sure that the engine breather is clear.
The seals at the t/meter cable do go hard and leak or just wear. It is en easy job to replace the seal but make sure you put the new one in the right way with the garter spring facing the radiator.
The seal is 30854 and the gasket is 36862511
David P
