MF4840
Edchainsaw
12-30-2004 17:07:46
what might be the problem if (since we have small implements) we gear up and Idle the 903 down.... I know you dont do that to some engines..
this machine is new to us.
Leland
12-30-2004 18:10:44
 Re: MF4840 in reply to Edchainsaw, 12-30-2004 17:07:46
ED nothing but 903s won't stand much lugging so don't slow the motor down too much .and there fuel hogs anyway.
edchainsaw
12-31-2004 14:16:42
 Re: MF4840 in reply to Leland, 12-30-2004 18:10:44
thanks... guess we might need to look for a bit of abigger tool or 2..
this one has 5,000 hrs. and aint been touched.. its been in the area all its life
parky
01-02-2005 09:01:32
 Re: MF4840 in reply to edchainsaw, 12-31-2004 14:16:42
You may want to consider doing two things before loading this baby up...
MF used the same differential gear size from the original 4800 design for all the later 4800 series and the 4900 series. You may want to check the gears and consider using the synthetic gear oils which are much superior lubricant to the organic based oils.
Most Cummins operators redo the crank bearings to ensure tight fit and good oil pressure, as the 903 loads the crank pretty good when she is topped out.
Keep her in good shape. As commodity prices tank, more of the older(but very good equipment) will become the norm in most operations.
Cheers
Edchainsaw
01-02-2005 18:09:19
 Re: MF4840 in reply to parky, 01-02-2005 09:01:32
thank you-- this one carry's good Oil pressure and has all the records in a nice file ... we knew the last owner and the dealer that sold it origianlly took care of it... its nice shape for 5000hrs..
Ken Lewis
02-10-2005 19:10:02
 Re: MF4840 in reply to Edchainsaw, 01-02-2005 18:09:19
Ed, I was a Massey Dealer here in Arizona for 20 years. Sold lots of the 4800 series tractors. One of the best 4 wheelers for the day. Built tough to stand the southwest. Loved the 903. Pretty much a problem free tractor
Good luck with yours. You will love that cab!
Leland
01-01-2005 01:54:09
Not bad machines drove 1 once and it was as good as 8640 JD and I bet the price is right. you won't ever want to step into a 2wd again after working ground with it once,no jarring teeth loose on rough ground good luck.
Edchainsaw
01-01-2005 13:05:51
 Re: MF4840 in reply to Leland, 01-01-2005 01:54:09
Drove it home today..
its an 1983 model-- sold finally in 1986 (the old dealer still knew the machine) everything still works on it.. unlike the 98Massey 8160 we have with 900hrs.. or the 92 3660 w/2000hrs...
we gave 16500 but the old dealer said it should have got it for 14-16,000.. oh well
edchainsaw
12-31-2004 14:16:32
