To 35 23C Standard diesel keep/sell
matt jones
12-29-2004 16:06:49
Hello, have a 1958 TO35 deluxe with the 23C standard diesel. Have had nothing but promblems. Had it running good one time. Am in the process of updating the fuel system. Will be hard pressed to keep her even if she starts running good. Anyone know anything about these 23C. are they just promblems?? should i get rid of her?
BOB UK
12-30-2004 06:51:10
 Re: To 35 23C Standard diesel keep/sell in reply to matt jones, 12-29-2004 16:06:49
Hi Matt
You don"t say what your problems are that you are having, but if it"s to do with starting this has always been a problem with the 23C engine.
Mine even after a rebuild (not by a professional I must add) would still not start without Ether when cold, but this is not to be used as the engine will always need it.
Once started however it is a very strong engine.
Ferguson exported the FE 35 fitted with the 23C engine to Canada and Australia, the Canadian export had a modification to the engine which included glow plugs to all four cylinders and a water heater, this I am told will start the engine down to -20 deg.
I was at a vintage tractor show a couple of years ago and had a very interesting conversation with a motor engineer, who was telling me and a few other collectors that there was nothing wrong with the 23C engine to which some of the old farmers there related their memories on starting this engine, but he was still adamant the engine was still a very good engine and carried on to explain that the likely cause of poor compression on starting was mostly down to a wrong head gasket being fitted, which if too thick would give poor compression, no one believed him but that"s old farmers for you!
I"ve had fuel problems on starting mine were the tractor would start but then die away. I tried all the usual things and more but without success but on posting this problem with all the checks on various Ferguson sites I received info on the fuel pump which should not be touched unless you have the experience, there is another fuel filter in it and on mine it was blocked and that was the problem! Has run better since being cleaned and I think with more power, must have been starving the injectors over a long time.
Carry on posting replies or email me direct and I will try to help you, or point you in the right direction to find the answers.
Good luck
BOB UK
England
barny
01-02-2005 09:07:01
 Re: To 35 23C Standard diesel keep/sell in reply to BOB UK, 12-30-2004 06:51:10
Am looking for good home for 4 cylinder diesel Ferguson and 2 front loaders! Any good suggestions?
Matt Jones
12-31-2004 14:08:15
Thank you Bob for the response. I have also heard about the head gasket. I beleive I have had several bad connections in the fuel lines prior to the injector pump. Was allways getting air in the fuel at the injector pump. I have done a complete rebuild to the engine, injectors, and injector pump. I got alot of $$ into it and it has only ran good for one short time. I will be putting her back toghter with all new fuel lines. But after all the headaches with it I beleive I will be glad to see her go.
