whats a ground speed P.T.O?
16535
12-28-2004 04:30:38
whats a ground speed P.T.O is it like a live P.T.O?
ben uk
12-28-2004 04:44:22
 Re: whats a ground speed P.T.O? in reply to 16535, 12-28-2004 04:30:38
Ground speed turns proportionally to the speed that the wheels are turning - put it in a higher gear you are going faster and the PTO will turn faster.
I have yet to find an application where i have needed to use ground speed. Im sure there are though.
polara
01-11-2005 00:23:36
 Re: whats a ground speed P.T.O? in reply to ben uk, 12-28-2004 04:44:22
I have a 165 and use the ground speed for a 3 point mounted pto driven side delivery rake. If you used normal pto you would have hay flying all over the field.
here
12-28-2004 06:11:05
Hey Ben, I've used it to unwind/unclog a sickle bar mower, unstick a post hole digger, and spread seed at less than std PTO speed. Just depends on what you're using at the time.
