MF 202
worth the work
Jim Kelley
05-26-1999 16:52:31
I've an opportunity to 'acquire' a '52 MF 202 with a 102 loader and a 185 backhoe. It's been sitting for some time and was worked hard in its day. Everythings there- just looks like a complete rebuild. It not running now, but is not frozen.
Questions I need help with are:
- Is a $3 to 4k budget realistic for the rebuild ?
- Configured as above what is the prefered rear wheel size?
- I understand that 8x16" front tire may be desireable ?
- Is this unit (with a Z134 gas engine) essentially the same as a MF 35 ?
- Any one have experience with this particular unit ?
- Any parts out there for this unit ?
Thanks for any and all help- [email protected]
B.C.
06-01-1999 06:46:33
 Re: MF 202 - worth the work in reply to Jim Kelley, 05-26-1999 16:52:31
We have a MH50 with a Z134 Continental engine. It's a close relative to what you describe. 400 hours ago on a 7000 hour engine we had a pump shaft failure like what Lucas describes. But we fixed it with a repair kit from Central Tractor and it hasn't been a problem since. This was up in northern Minnesota in the winter. We used 5W-30 oil after that in the cold months and have not had it happen again.
We later went through the engine with new sleeves, pistons, valves and so on and it's been fine since. That was coming anyway and had nothing to do with the oil pump.
500 to 1000 bucks would do one of those engines depending on what you ran into. You might want to at least pull an inspection cover over the trans to see that the gears aren't trashed, and maybe drain some trans fluid looking for gear teeth chunks.
It would seem like another 2 or 3 thousand would get a loader and hoe rebuilt (maybe with appropriate generic bushings, cylinder rebuild kits,hoses etc). That's assuming you do most of the work yourself, and that there isn't any real structural damage. If you have it done, find out what 3 or 4 man-weeks of shop time costs, and add that in.
Massey tractor parts are available used from places like Central Tractor, and the dealerships have some new parts eventually available. The hoe and loader parts would probably have to be improvised. You are talking about a machine that's some 40 years old.
If you really want to move dirt, maybe you ought to look at something like a usable Deere 410.
On the other hand, if you're up to the effort, you might not lose too much by getting it resurrected, especially if you can do most of it yourself.
Matt M
04-14-2000 21:27:29
 Re: Whats the horsepower of MF 65 ? in reply to Jackey, 04-14-2000 19:37:22
My service manual says 52 HP.
Jim
04-18-2000 12:14:38
 '59 MF 50 Help in reply to Jackey, 04-14-2000 19:37:22
B.C.
06-07-1999 06:26:07
 Re: Re: Re: MF 202 - worth the work in reply to Jim Kelley, 06-06-1999 08:13:14
17 years ago when we got our MHF 50 I contacted Massey and wound up talking to a plant down in Iowa that was shutting down. They xeroed an owners manual. I got an I&T rebuild manual from Central Tractor. Those two things, plus the nearest dealer being 40 miles away got me started.
I would guess the engine work would be pretty similar to the ag tractors. I would guess most of the loader and hoe hoses, bushings and so on would be replaceable at the generic level, assuming AGCO is less than forthcoming with a detailed parts list.
You sure got it for the right price, good luck in getting it back into shape. Work safely.
