Pulsing Lift
Hal Herndon
12-27-2004 04:51:50
The Lift on my MF180 just recently started pulsating on the up and down. It will still lift but a lot slower than usual. I changed the oil but didn't find a filter. I have an IT manual on the way but in the mean time does anyone have any answers as to why the lift is pulsing.
Big Dean
12-27-2004 07:31:57
 Re: Pulsing Lift in reply to Hal Herndon, 12-27-2004 04:51:50
A loose master control spring is the only thing I know of that will cause one to pulsate going down & that is very rare there are a few things that will cause one to pulsate while raising. [1] A loose master control spring [2] When using the position control lever the draft lever not being pull back to the fully raised position. [3] The most common thing to cause this is either the intake & discharge valve or a broken piston ring in the three point pump. If it started all at once it may have got something under one or more of the valves. If I can be of further help Email me
