MF 135 question
David Mcadams
12-23-2004 12:07:48
Can anyone tell if they made a belt pulley system for the MF 135 and if they did was it like the old fords that bolted around the PTO housing. Anyone got any pics of one? Thanks Dave
TLD in NC
12-27-2004 11:38:37
 Re: MF 135 question in reply to David Mcadams, 12-23-2004 12:07:48
David in answer to your question about belt pulleys for MF 135's. They are available. One to fit a MF 35, MF 50, MF 150 and maybe others will fit the MF 135.
David Mcadams
12-27-2004 13:02:28
 Re: MF 135 question in reply to TLD in NC, 12-27-2004 11:38:37
Thank you all for the information. I have a buzz saw and use an old hit or miss on it. I don't like to drag out the old engines in the winter and thought that a pulley on my 135 would be handy. Probably finding one would be difficult. Thanks again. Dave
Roy in UK
12-25-2004 23:31:50
Yes they were available over here and we had one, but I think it was bought with a 35, but when we traded the tractor in for a 135 it fitted it perfectly. ( same rear end more or less) I suppose they were available across the pond though.
So. IL. Farmer
12-23-2004 19:19:39
Yes they did make a belt pulley for the MF135.My owners manual shows one as option attachments.But I never seen one.Good luck. John
parts man
12-23-2004 16:33:24
I've seen one from a MF 50. It bolted around the PTO, and I think would also bolt onto the 135.
Roy Craft
01-05-2005 11:16:33
 Re: MF 135 question in reply to parts man, 12-23-2004 16:33:24
We had a belt pulley for our 35 diesel to drive the threshing mill and later used it on our 135. The same pulley would fit even some of the later models as the bolt pattern around the PTO didn't change. Check out older Massey farm dealers or tractor used parts dealers.
