MF 231 Brakes
37 chief
12-22-2004 21:52:04
The brakes on my 231 are not good. I checked the lining which is good, was glazed, but I roughed them up with sand paper, but didn't do much good. Any suggestions? Stan
DavidP, South Wales
12-23-2004 11:10:42
 Re: MF 231 Brakes in reply to 37 chief, 12-22-2004 21:52:04
Hi,
Make sure that they are adjusted up at the drums to start. Look for wear where the end of the shoe sits on the square at the end of the brake shaft. If found, grind out and fill with weld and grind back. You can leave them slightly proud but they must be the same on both sides.
Carry out full adjustment and you should have super brakes.
DavidP
