diesel leaking between tank and steering
hank n' tx
12-21-2004 16:40:25
i have diesel probably leaking from or around my injectors but have also noticed it leaking somewhere between the tank and the steering column. havent had a chance to really get into it and find out where its coming from. the tractor is mf 50. where do you think the latter leak is coming from and what can i do to fix both leaks? thanks hank
pineybump
12-23-2004 11:50:04
 Re: diesel leaking between tank and steering in reply to hank n' tx, 12-21-2004 16:40:25
most mf's have a rubber hose which returns excess fuel from the injectors and fuel pump to the fuel tank. The return goes into the upper center of the tank at the rear (or just in front of the steering column. On some models you can see this return from the battery box access.
chief 83
12-23-2004 20:53:50
 Re: diesel leaking between tank and steering in reply to pineybump, 12-23-2004 11:50:04
That's where my 245 was leaking. Simply had to slide the hose back on the metal tube on the tank. Had to remove the battery to get to it.
