price for a MF 65 dieselmatic w/ multipower
jimFlem
12-19-2004 08:04:15
I"m looking at a MF 65 dieselmatic not sure of the year, but looks to be in good shape, cosmetics good/stays in garage. what is the going prices for these and what are the pitfalls to look for as far as problems. I haven"t started or driven it but owner says its A ok.a range of prices would be good,
also what is involved to put a F/E loader on it. are the factory hyd. enough? what soes this cost?
Boss Hog
12-20-2004 05:53:46
 Re: price for a MF 65 dieselmatic w/ multipower in reply to jimFlem, 12-19-2004 08:04:15
I could see a tractor like that going for $4,000 to $5,000 around here.
I wouldn"t pass it up if you can afford it.
Randy MF65
12-19-2004 15:57:57
If it all works fine I would say in the $3,000-$4,500 range. Very worthy tractor. I paid $3200 for mine with a loader but it needs some work to make it pretty.
Main Issues: Front bolster,is it cracked? Multipower, does it work or leak oil? It will work great with a loader but the tractors hydraulics are slow.You can add a front mount pump to the perkins motor...Does it has power steering, you will need it with a loader.
jimflem
12-19-2004 17:24:36
 Re: price for a MF 65 dieselmatic w/ multipower in reply to Randy MF65, 12-19-2004 15:57:57
yes the tractor has power steering, where do you look on the for tell-tale leaks?
Randy MF65
12-20-2004 12:52:30
 Re: price for a MF 65 dieselmatic w/ multipower in reply to jimflem, 12-19-2004 17:24:36
Look for the leaks under the shifters on the bottom of the tractor. You should see a small drain hole in the trans case. If you put the tractor in high range/ high multi power and shoot it down the road for a little bit in 2 or 3rd gear. IF the seals are bad it will drip out the hole in the trans case. Take a piece of a coat hanger and stick it in the hole to make sure it don't have some permatex in it keeping the oil from dripping out. You can read about this on Big Deans sight.
http://hometown.aol.com/bigdean62/index.html
