Rocker arm shaft assembly MF35 gas
Richard Mi
12-13-2004 12:25:14
Checking valve clearance for noise on 134 gas and found cotter keys worn off and flat washers and conical shaped springs off shaft and laying on cyl head. Need assembly sequence.Is flat washer next to key and small diameter end of conical spring next to rocker arm?
Gerald J.
12-15-2004 21:59:10
 Re: Rocker arm shaft assembly MF35 gas in reply to Richard Mi, 12-13-2004 12:25:14
I don't remember the order right now, I'm sure its in the parts book upstairs. Be sure to check and replace the corks in the ends of the rocker arm shaft so the oil gets to the rocker arms.
There might be a wear pattern on the end rocker arm and the washer to show which end of the spring was against each.
Gerald J.
