Carbon
GDBAR
12-13-2004 05:22:22
What is the way to remove carbon buildup on pistons/under old rings?
Thanks Gary
brtx
12-16-2004 00:15:53
 Re: Carbon in reply to GDBAR, 12-13-2004 05:22:22
we used to set pistons in water high enough to cover ring grooves.then dump a bottle ofdihwashing soap and let them soak overnight.
fred kobs
12-14-2004 06:20:01
I have a cleaner tool by lisle like others have described and found that breaking an old ring in half and sharpening it on the grinder to be better for the piston and my disposition. If you spray a little carb cleaner in the groove helps. There is probably a good groove cleaner on the market but the lisle soured me on them. Just my pennies worth. Fred
Jason(PA)
12-13-2004 16:46:38
There is a tool for that. They work great,but one thing to remeber is don't dig in too much!! Some pistons you could probably cut in half with it with out really putting too much effort into it.
Willy-N
12-13-2004 06:48:47
They have a tool for that I beleive called a Ring Lan cleaner, you run it around the piston with the knotch in the grove. You could also use a broken ring carfuly if that is all you had. You can use a fine wire brush on the top of the piston being careful not to round the edges ot hit the top ring lan. Mark H.
