MF 135 STEERING BOX
Scotty
12-11-2004 16:00:02
I have a MF 135 and the steering box is wore clean slam out! Any body know where I can find one ? Thanks for your time
Scotty
Ray,IN
12-11-2004 20:51:38
 Re: MF 135 STEERING BOX in reply to Scotty, 12-11-2004 16:00:02
I rebuilt mine using parts purchased from ----- -- I did not use the original type thrust bearings on the shaft assembly, instead I used thier Delrin replacement bearings and they work very well. To remove the bottom thrust bearing cone you must have a blind hole bearing puller. I borrowed one from AutoZone that worked great, and it was free! A throwaway replacement gearbox is available for around $550, if you can't rebuild yours or find a good one to rebuild. NOS steering gear boxes are not available, unless you are very lucky and find a retired dealer with one.
Ray,IN
12-11-2004 20:49:32
I rebuilt mine using parts purchased from ----- -- I did not use the original type thrust bearings on the shaft assembly, instead I used thier Delrin replacement bearings and they work very well. To remove the bottom thrust bearing cone you must have a blind hole bearing puller. I borrowed one from AutoZone that worked great, and it was free! A throwaway replacement is available for around $550, if you can't rebuild yours or find a good one to rebuild. NOS steering gear boxes are not available, unless you are very lucky and find a retired dealer with one.
