weak 3pt on MF 20C
Ed L
12-09-2004 19:29:49
I have a mf 20c with weak 3pt hitch. It will barely lift a snowblower. fluid level is good. I thought I read somewhere that a clogged pickup filter can cause this if so where do i find it also i thought i seen somewhere something about o"rings around a preasure pipe fluid could be leaking past. If anyone can help on this let me know thanks, Ed
Big Dean
12-10-2004 10:38:23
 Re: weak 3pt on MF 20C in reply to Ed L, 12-09-2004 19:29:49
Ed there are several things that can cause the problem you are having. The filter will usually not cause one not to lift. It will usually cause them to lift slow or jerky. The O-ring I think you are talking about is the stand pipe O-ring it has one on each end. Usually when they go the lift will not lift a load at all. I suspect you have either a wore out pump a bad relief valve or a weak master control spring. Those are the most common causes for the problem you are having. If I can be of further help Email me
