Massey Harris Serial Number
Schultzy
12-08-2004 20:12:08
Hello,
I'm wondering if there's any way to find out the serial number of my Massey Harris 555 Diesel. The serial number tag is beaten and unreadable. Is there any other place it's located on the tractor?
Thanks,
Russ
Schultzy
12-11-2004 17:11:31
 Re: Massey Harris Serial Number in reply to Schultzy, 12-08-2004 20:12:08
Hello,
I checked my tractor and I found the number on the Diff. Case. It says D1SF 20257.
do you know production numbers?
Thanks,
Russ
Bruce C
12-12-2004 10:12:51
 Re: Massey Harris Serial Number in reply to Schultzy, 12-11-2004 17:11:31
D-diesel,1-regular altitude,S-standard tread,F-foot clutch.#20257 is a 1956.
KJ
12-11-2004 20:13:52
#20257 would make yours a 1956.
Bruce C
12-09-2004 21:11:39
The serial number is stamped into the top of rear-end houseing on the left-hand side just ahead of the clutch pedal.You may have to clean off some paint to read it.Send me the number and I will be able to tell you what year it is.
Bruce C
12-08-2004 21:11:10
The serial number is stamped into the top of the rearend housing below the dash.I not sure which side.I will be out to where I have my tractors stored and I will check the location on my 555.
BJ Matthys
12-12-2004 09:26:57
 Re: Massey Harris Serial Number in reply to Bruce C, 12-08-2004 21:11:10
We have recently purchased a Massey Harris tractor for restoration, however it is unknown at this time what the Massey is? The metal plate on that is supposed to be located mid way on near the rear of the tractor is missing. Stamped into the casting next to the clutch pedal is the following:
763396M2
Is there a way of finding out the model and year by this serial number? Thanks
BJ
Alberta Mike
12-09-2004 05:46:36
Take your snow shovel with you on the way to see your 55 Bruce. At least up here you'd have to. How much snow did you get down there?
