MF35 4cyclinder
mike looby
05-24-1999 07:02:26
Anyone any ideas on the root cause of these tractors starting problems and any ideas on how they can be made start reasobly easy vs cost?
Mine needs a good battery, easi-start and some luck!
Russ R
04-15-2000 06:44:13
 MF65 Air Cleaner in reply to
Gerald
05-24-1999 08:34:25
 Re: MF35 4cyclinder in reply to mike looby, 05-24-1999 07:02:26
What it took for my MF-135 was a rebuild of the starter. I had new bushings put in, installed a new solenoid (old solenoids get rusty and sticky sometimes), and it needed new brushes and a cleaning to get rid of the ground up old brushes. I put in a sealed battery and its been doing fine for a long time.
Then make sure the choke wire closes the choke fully. And pull the choke while cranking with the throttle opened about 1/3. Fires my 135 fine that way. Open the choke most of the way as soon as it hits or you can flood it.
Gerald
