Lift arms jerk when raising 3 pt
Ron35
12-06-2004 09:58:12
When I go to raise my 3 pt on my MF35 it jerks when about a 1/3 third of the way up. Did'nt notice it last time I worked the hydraulics. I don't have anything hooked up to the hitch.
Someone told me I need to bleed the system??
If so, hows it done?? Still waiting on my shop
manual.
sibby(Aus)
12-06-2004 22:51:06
 Re: Lift arms jerk when raising 3 pt in reply to Ron35 , 12-06-2004 09:58:12
Ron, David has given some very good advice, what grade of oil is in the rear end, if you have a strainer fitted to the hydraulic pump it could be starving your pump for oil, also too thick a oil has same effect. cheers.
DavidP,South Wales
12-06-2004 13:05:24
Hi,
Erratic operation of the lift arms can be down to several things.
1/Have you checked the oil level? Very low oil level can allow air into the system. Replace to correct level and operate several times. Better if you can attach light implement.
2/Being a MF 35 you may have 'solid' pistons or ringed pistons in the pump. Ring breakage and a valve failure will cause this promlem. Think of a four cylinder car running on three cylinders.
3/Unlikely but you may have a major leak within the system and the internal linkage is trying to compensate for the oil being lost.
Regards
DavidP
