MF 65 Mk 1 Brake Rattle
Phil in Aust
12-02-2004 17:45:55
Hi,
I have just completed a full rebuild on my MF 65 Mk1. The rear end has been fully stripped and lots of bits replaced.
The brakes were bad before the rebuild so almost everything was replaced. The brakes now work very well, but they rattle when not in use. As soon as I put slight pressure on the brakes the rattle stops.
Does anyone know what may be causing the brakes to rattle?
Thanks
DavidP,South Wales
12-03-2004 12:18:31
 Re: MF 65 Mk 1 Brake Rattle in reply to Phil in Aust, 12-02-2004 17:45:55
Hi Phil,
Assuming that you have disk brakes. Not a problem we have come across before, but think it might be the new disks (if fitted) "bouncing" between the actuator and axle casing. Suggest driving the tractor for an hour or so with light pedal pressure to bed the disks in. Not enough pressure to cause fade or overheating. Let us know if it works.
Regards
DavidP
