Harrow disc model 25, Massey Ferguson
Denis Larochell
11-30-2004 10:02:23
I would to by one of thoses disc harrow but I cannot find the data of that equipement. Mainly
I know this have 20 disc, but need to know the weight and the tractor recommanded for.
At the same time I do own a rear blade Massey built in the 70 that is 6'0" wide and adjustable
at angle and form up and down monted on 2 round
tubes. Any place to find data would help
Thank you in advance
Denis Larochelle
Quebec Canada
Tom in VA
11-30-2004 14:51:56
 Re: Harrow disc model 25, Massey Ferguson in reply to Denis Larochelle, 11-30-2004 10:02:23
Denis,
I have a 20 disc model 25. I'm not sure of the weight but it is around 600 pounds(272 kilos). You can pull it with a MF 135 with out much trouble. Even if I angle the discs hard it will pull the 20 disc.
I am very pleased with my 25. I like how I can change the angle of the gangs from the seat of the tractor. This is very handy with the type of soil we have in this area. I have the original owners manual for the model 25 disc harrow. If you decide to purchase it, I might be able to scan it on a PDF scanner for you.
The weak points of this unit are:
-They develope a lot of play in the adjustment mechanisms with age.
-If it has wood bearings you will have to convert the bearing and spool to a metal one because the parts are no longert available.
Tom
Mark in TN
05-20-2005 10:18:05
 Re: Harrow disc model 25, Massey Ferguson in reply to Tom in VA, 11-30-2004 14:51:56
In December I purchased a MF No. 25 Disc and have just about finished restoring it. (painted it blue though) Was wondering if you still have that PDF document of the users manual? Could you send a copy? [email protected]
Thanks in advance!
Denis larochelle
12-01-2004 09:40:29
Thank you for the info
We do have a compact tractor 4 wheels drive that
is equivalent to 135, NH TC 30 with the hydraulic
capacity of 1325 lbs at 24" so you just confirm that this would fit on your tractor.
Yes I would be interested in you document in PDF
let me now how you want to handle that Thank in advance.
Denis.
Tom in VA
12-01-2004 15:47:34
 Re: Harrow disc model 25, Massey Ferguson in reply to Denis larochelle, 12-01-2004 09:40:29
You're welcome Denis. You can give me your email address and I'll email the PDF to you or if you are not comfortable with posting an email address you can give me your postal address and I'll mail you a copy of the manual. It's only 18 pages. Tom
Denis Larochelle
12-02-2004 05:03:42
 Re: Harrow disc model 25, Massey Ferguson in reply to Tom in VA, 12-01-2004 15:47:34
Good morning
Once again thank you for you cooperation my Email adress is "[email protected]"
Once a get the harrow at my home I will send you
a picture. I known the adjustement lever are
on top of the disc and you have to go there to adjust.
Thank you.
