Hydraulic leak
Jack in CA
11-29-2004 08:25:44
Just replaced clutches in automatic shuttle on a MF 30B. Now am getting fluid under pressure into torque converter chamber from pump. Saparated engine again and replaced seal around shaft from transmission to torque converter. Checked all bolts holding things together . No cracks, etc. am puzzled. Anyone have any ideas?
Big Dean
11-29-2004 09:26:55
 Re: Hydraulic leak in reply to Jack in CA, 11-29-2004 08:25:44
Hi Jack Did you check the pump drive hub runout? it has to be less than 0.010 or the pump seal will not hold for long. It should to be checked every time you split one of those.
