Looking at 165 diesel
Gary in TX
11-28-2004 06:47:51
Hey guys, the 3 point is not working. Going through the hyd pump is the obvious but was just wondering if there could be any other cause?
Big Dean
11-28-2004 13:21:23
 Re: Looking at 165 diesel in reply to Gary in TX, 11-28-2004 06:47:51
One thing that David did not have in his post is if the lift will work without a load but will not lift a load it could be a weak master control spring. I have a picture that shows how to hook a chain to check the master control spring. If you would like to have it send me an Email.
DavidP,South Wales
11-28-2004 09:15:07
Hi Gary,
Possible causes of 3 point linkage not working.
1/ Check oil in transmission.
2/ If isolating valve at front of hydraulic cover fitted ensure that correct position of control lever/spool is selected for linkage.
3/ Does clutch pedal have second stage if tractor is dual clutch type? If so does second stage "feel" right.
4/ If IPTO does pto turn under power?
5/ Do you have hydraulic power to operate external ram i.e. trailer?
Please check these and post another message with your results.
Regards
David P
