MF 135 Air Filter
JWyatt NC
11-26-2004 11:38:13
Hey guys, just read in Operators manual I bought from a dealer that there is a solution to soak the air filter element in to clean. Is this a certain solution or is there any alternatives? As always thanks for your help. And Happy Thanksgiving.
DavidP, South Wales
11-26-2004 11:50:55
 Re: MF 135 Air Filter in reply to JWyatt NC, 11-26-2004 11:38:13
Hi,
I assume you are talking about the steel mesh element fitted to older 135's. If so, an alternative is to turn the element upside down and support it on two sides. Pour some petrol over the clogged mesh. Make up a taper of some sort that will allow you to ignite the petrol in the mesh at arms length and stand well back. When dead and cool tap the element against a tyre and the burnt debris will fall out. You may have to do this several times depending on the clogging. (PReferably done on a calm day)
David P
Ray,IN
11-26-2004 21:18:36
 Re: MF 135 Air Filter in reply to DavidP, South Wales, 11-26-2004 11:50:55
My owners manual is the same. I, however, have found that new disposable elements are cheaper than a can of cleaner.
