MF 50 PTO Seal
D. Hall
11-25-2004 06:57:46
The seal around the PTO on my MF 50 (1962) is leaking What is the the best way to get at this seal for replacement. Thanks D. Hall
Bill VA
11-26-2004 11:16:51
 Re: MF 50 PTO Seal in reply to D. Hall, 11-25-2004 06:57:46
If you are talking about the rear PTO seal where the shaft comes out of the tractor (vs the input shaft inside the tractor), I think it is an easy replacement (as far as this stuff goes).
I think that you remove the bolts around the shaft and the plates come off and the shaft will slide out. From there you have the seal and bearing that hold the shaft.
Do a search on this site, also I think that the MF35 will be the same too - so there is another search too.
You need to get yourself a set of manuals for this tractor - they show what to do in detail.
Bill
