TO 35
jgh
11-23-2004 11:54:44
I have a TO35 with less than 200 hours on an overhauled engine. Recently, the manifold will get red hot after about 30 minutes of heavy use. I"ve had the timing checked twice and it seems to be fine. Any ideas? I"m trying to find a new air cleaner to eliminate that as the problem. Unfortunately, the only air cleaners available for this model are after the serial number 204181. My TO35 has a serial of 198437. Do you know if the newer air cleaner would work? Both are oil baths and the newer one is slightly bigger. Any help would be appreciated.
Jerry/MT
11-23-2004 18:59:17
 Re: TO 35 in reply to jgh, 11-23-2004 11:54:44
I'm presuming we're talking about a gas tractor.When you had the timing checked, was the advance timing checked also? If it isn't advancing per the centifugal advance schedule, your spark aybe late and the exhaust valve will be open before combustion is complete. That's a good way to burn the valves and make the manifold red hot. The other thing to look for is a leak in induction system downstream of the carburetor. That will cause a lean mixture that will yield a hot exhaust. These Continentals run with a slightly enriched mixture that utilize the excess fuel for charge cooling. So check joint between the carb and the intake manifold as well as the manifold to cylinder head joint for leaks. Don't do any heavy duty work until you sort this out or you may be rebuilding the head.
parts man
11-23-2004 16:09:04
First bit of information we'll need to help is gas or diesel?? ;)
