MF 135 Circa 1971 Diesel
Paul USA
11-21-2004 13:27:32
Where do I fill up the engine oil. Where do I fill up the power steering fluid?
Big Dean
11-21-2004 18:29:17
 Re: MF 135 Circa 1971 Diesel in reply to Paul USA, 11-21-2004 13:27:32
The engine oil filler neck is sticking up on the left side of the timing cover it has a T handle plug in it. When you turn the T handle counterclockwise it loosen the rubber plug in the neck. when you turn it clockwise it tightens the plug. The power steering pump is on the back of the timing gear case on the right side of the engine it has a round can about 6 to 8 inches with a plug in it for filling the reservoir. Fill it with the engine running then turn the wheels from stop to stop a few times the get the air out of the system then refill the reservoir. If I can be of further help Email me
