1971 MF135 D
DonaldinKy
11-18-2004 15:35:52
I just got a MF135 i am new to the mf is there a safty for the starter that i cant find. the thing wont turn over and the lights burn. There a knob beside the starter is that the fuel shut off It has the 3 cyl Perkin engine. Thanks Donald
ben uk
11-19-2004 12:36:13
 Re: 1971 MF135 D in reply to DonaldinKy, 11-18-2004 15:35:52
congractulations on buying th best utility tractor ever made in mine, and many other peoples opinions. That perkins will never let you down.
jerry in alabama
11-19-2004 02:53:07
I just bought a mf 135 gas ,both the hi-lo lever and the shift lever have to be in neuturel for engine to start
MF
11-18-2004 17:23:08
Shift the right gearshift into the 'center' position, forward is LOW, backward is High, press in clutch, Push fuel shutoff in, crank engine, Let her run, Enjoy!
C. T. in Oklahoma
11-18-2004 17:20:43
Donald, I don't want to mis-lead you, but my MF35 requires that the gear shift be in neutral, and the hi/lo range be in neutral. I suspect yours is the same. My fuel shutoff is on the left side of the dash and is a push/pull shutoff.
C. T.
