spliting tractor 135
gdbar
11-15-2004 05:29:44
I am overhauling my 135 with z145 engine when removing the engine do I need any special tools to take the clutchs off? I purchased a video on the overhaul and it dose not show anything but I have been told that I need some type clamps is this true?
parts man
11-15-2004 19:56:41
 Re: spliting tractor 135 in reply to gdbar, 11-15-2004 05:29:44
You won't need any special clamps to remove the clutch from the fltwheel, but if you are going to overhaul the PPA, there is some special clamp set-up recommended.
Bob N.Y.
11-19-2004 17:44:12
 Re: spliting tractor 135 in reply to parts man, 11-15-2004 19:56:41
If your clutch is the same as my 65 and 165, you should put 3 1/4" T-bolts with jam nuts in the clutch assembly before you unbolt it from the flywheel.
Jerry D
11-21-2004 22:30:07
 Re: spliting tractor 135 in reply to Bob N.Y., 11-19-2004 17:44:12
If you are changing your 134 to a 145 will you have the old motor. I am looking for a Z134 rebuildable block. Please e-mail me back if you have the motor for sale. Jerry
