101 Jr. Standard
Sam Moore
11-13-2004 14:35:06
Anybody know how to remove the lock pins that hold in the king pins in the axles of a 101 Jr. Standard from 1944.
The pins are just below flush on the front of the axle and stick out maybe 1/16 inch in the rear. The rear part of the pin has a flat spot milled on the side toward the king pin. The pins must have a way to lock them into place, but I can't figure it out. My I & T manual says "it should be evident how to remove the king pins." Well, it ain't evident to me.
Any advice?
Sam Moore
Bruce C
11-14-2004 16:59:00
 Re: 101 Jr. Standard in reply to Sam Moore, 11-13-2004 14:35:06
I have a super 101 and a 102 junior.I will be out where I have them stored in the next couple of days and I will take a close look at the king-pin assembly and get back to you with what I find.There has to be a easy way to get them out.
Sam Moore
11-14-2004 17:20:03
 Re: 101 Jr. Standard in reply to Bruce C, 11-14-2004 16:59:00
Thanks, Bruce.
I appreciate your help.
Sam Moore
11-14-2004 16:16:23
Thanks, guys. The problem is that there isn't a threaded end. I've taken out lock pins on several other makes that the small end of the tapered pin was threaded and a nut held the pin in place. There's no nut, no threaded end and no obvious way the pins are locked into place. I hate to just go beating on them. I have a parts book for the 101, but there isn't a single illustration in it, just a list of part names and numbers. I keep thinking the flat milled surface on the protuding end of the pin has some significance, but I can't figure out what it is.
Bruce C
11-14-2004 08:57:33
The lock pins are tapered.You drive them out by hittimg them on the threaded end.They can be hard to get out sometimes.Try not to sweell up the end to much when hitting it.
angleiorn
11-13-2004 15:38:13
THEY ARE TAPERED DRIVE THEM OUT WITH A PUNCH
