MF 135 hydraulics
glenn deckert
11-13-2004 00:04:27
I've got an early 70's 135 that gets very infrequent use (grading the driveway or removing snow) and spends much time sitting inside a shed I built for it. The other day, I fired 'er up to do some grading and started pouring hydraulic fluid from under the block with the hydraulic controls. Anyone care to guess what's wrong and what I need to do to fix it? Thanks for the help. Glenn
sibby(Aus)
11-13-2004 01:35:58
 Re: MF 135 hydraulics in reply to glenn deckert, 11-13-2004 00:04:27
Glenn, Replace the o,rings under the block and the hydraulic stand pipe. cheers.
David P, South Wales
11-13-2004 11:01:03
 Re: MF 135 hydraulics in reply to sibby(Aus), 11-13-2004 01:35:58
Hi,
Sibby said it all, but if the pipe comes out (only part way if you have Pressure Control fitted), all the way if not. Take time and patience to make sure that the pipe re-engages in the bottom end and that you don't loose it.
It's engaged when it looks vertical. Push gentle and it will engage. Check the condition of the PTFE (white) back-up rings and replace if required.
Stand-pipe O rings 195 561 M1
PTFE washer 195 874 M1
Cap/block O ring 195 561 M1
Tighten block bolts to 55 lb/ft if you can get a socket onto them.
Regards
David P, South Wales, UK
