180; 3 pt. hitch advice.
Marty G.
11-09-2004 16:38:19
Hi folks. This wee-end, I'm about to lift the cover of our MF 180 to re-seal the lift cylinder. Is there anything else I should look for inside and that would be wise to do at the same time. Your sound advice will be appreciated. Thanks in advance.
Marty.
Big Dean
11-10-2004 09:20:30
 Re: 180; 3 pt. hitch advice. in reply to Marty G., 11-09-2004 16:38:19
In case you do not know this there is a roller that has to be removed from the pump control lever you do that by removing the access plate on the right side of the rear center housing. This is to prevent the pump control lever from being pull from the pump.
marty g.
11-10-2004 09:49:32
 Re: 180; 3 pt. hitch advice. in reply to Big Dean, 11-10-2004 09:20:30
Thanks Dean!
I was aware of it from reading your site.
Is there anything else in there I should consider rebuilding while I'm in there. This tractor is used for feeding the cows with green round bale, it is getting weaker and when tractor is shut off, the hydraulics drop right down. Thanks again Big Dean.
